Topic: cranks no start **Diagosed** (Read 27444 times) previous topic - next topic
Re: cranks no start **Diagosed**
interesting timing cover thing i never noticed until now......
maybe this is why you are leaking at the top left and right of your cover???????
https://youtu.be/4KyS-1ptKeI
Im not a 5.0 guy but iirc those holes are for the clockwise rotation waterpumps.
Room for days and days and days................
I am bewildered by what all the hub bub is about doing an oil pump or pan gasket in the car.
remove starter, motor mounts, raise engine and it drops down a whole bunch.
oil pump & starter on order.
https://youtu.be/zWGRmr1n8VU
Bench testing an oem 302 oil pump just for the sake of saving it as a spare or not.
if i can get a gear set,, i will save it back.
So,, as advised earlier,,, getting a new pump turned out to be the best choice here.  I did not go with a high volume ,, just a standard.
I did mis- identify the year of the casting number on the pump housing,, begs for forgiveness, C2xx would be 1962.,,, not 72.
https://youtu.be/ABdssPdycco
Sounds good!
1988 Thunderbird TC, 5spd
'21 F150 Powerboost
'17 Husqvarna TX300
compression numbers coming today as the final update.
part 9 vid done.. compression test complete and i will be honest with you all,,,, i was surprised with the outcome.  its almost jaw dropping to be frank.
https://youtu.be/AcP7DmVlhBQ
