Topic: 88 Turbo Coupe Project (Read 1906 times) previous topic - next topic
Figured I'd make a project thread to share my experience of putting my TC back on the road  :birdsmily:
got it back in September of 2019 for $1000 and I've done quite a lot of work to it
I'll add some pictures to the thread later
  • swapped out the teves master cylinder with a good used one since the pump was dead on mine
  • rear end rebuilt since it was worn out / I think it was run low on fluid since it had a leaky wheel seal and it ended up wearing out the rear end
  • valve job done on the head and installed a RR Cam with roller followers and the nice ranger valve cover gasket
  • new rack and pinion, tie rod ends, and sway bar bushings / end links
  • had a hurst short throw in it already which was nice since the factory shifters are junk
  • Esslinger cam gear to retard the timing some to gain some top end back with the RR cam
  • catch can between the intake and PCV valve
  • ported E6 manifold with the EGR port converted to a wastegate port
  • Stinger FMIC
  • Stinger 3" single exhaust with a dynomax ultra flo and no catalytic converter
  • modified fox mustang cold air intake to work for the 2.3T (basically just trimmed the pipes down)
  • Aeromotive AFPR set to factory pressure (got it for cheap and figured I'd need it at some point)
  • powder coated the valve cover, upper intake, and coolant lines
  • new clutch slave and master
  • autometer boost, oil pressure, and water temp gauges since the factory ones weren't too reliable
I recently acquired a parts lot that came with a mildly ported head with a Bo-port 2.1 cam so I'll be installing it soon
also bought a rebuilt factory .63 SVO turbo to replace the IHI with
the Pimp ECU is probably the next big upgrade I'd like to do so I'm on the lookout for a used one
1988 Thunderbird V6: all stock other than the radio
1988 Thunderbird TC: Chip's Ranger R Cam (with Esslinger cam gear), Stinger FMIC, .60/.63 SVO Turbo, Pimp V1.4, Spartan2 Wideband, Forge DP BOV
Re: 88 Turbo Coupe Project
Sounds like an awesome project and you weren't kidding...you have been pretty busy.  Keep us updated on the progress, some inspiration is always a good thing.
You have been busy!!!  Sounds nice.
Any pictures?
1988 Thunderbird TC, 5spd
'21 F150 Powerboost
'17 Husqvarna TX300
Here's some pictures
I'd like to get a paint job one day lol
good work!  Whats the gold foil on the intake pipe?
Mike
I bought the intercooler kit used so the previous owner had that heat tape on it already
