Topic: Springs for V8 (Read 10105 times) previous topic - next topic
Re: Springs for V8
:like:
Re: Springs for V8
Reporting back. The SN95 springs worked out great. They look almost identical but drop the car to a nice front stance. Glad I don't have to do that job again anytime soon!
Alright.  Pics man!   Pretty please...
Mike
Re: Springs for V8
Here she is! First pics posted since my V8/T5 swap!
1988 Mercury Cougar LS
5.0HO + T5 Swap + Suspension/Brake Mods
Re: Springs for V8
Those pics are with sn95 springs just in front, correct?
Mike
Re: Springs for V8
Correct. SN95 in the front, TC in the back.
Re: Springs for V8
Beautiful car BTW!  Stock engine with flat top pistons?  I Gt40p to use also and top end.  You using a stock HO cam?
Mike
Re: Springs for V8
Thank you sir!
These are new springs all around.
I started with a stock 87' Tbird 5.0 (dished piston) low mile block. I added rebuilt GT40P heads and Scorpion roller rockers (stock ratio). I used a stock new HO cam & roller lifter setup. Then I added the explorer top end and 65mm throttle body. Since I stuck with speed density, I used 21# injectors to try to make up for the added airflow. Still learning this stuff, so not exactly sure how efficient my setup is, but it working for me. This is more than enough power for what I'm doing, especially through a T5 and a 3.45 trac-loc rear. The car feels like a totally different animal compared to when it had the anemic 3.8L -> AOD -> 3.08 open dif. setup.
Re: Springs for V8
Looks good. Sits about like my car, which is surprising considering you have iron heads in your car and mine has aluminum. It's probably the AOD in my car weighing it down.
Re: Springs for V8
That's correct, no valve reliefs in pistons.
Re: Springs for V8
Where are you getting the 21lb injectors?  Ive not heard of those.
Mike
Re: Springs for V8
Got em' in a trade at some point. I believe they were for a late 90's modular motor.
Re: Springs for V8
Probably just the 4 hole yellow ones from mod motor cars.  I thought they were 19lb 4 hole pintels.
Mike
Re: Springs for V8
If they're pink, they're 21 pounders...those came on IIRC late o2 through '04 Stang GT, NOT Cobra/Mach.
Orange=19
Pink=21
Blue=24
https://www.stangnet.com/mustang-forums/threads/24-lbs-injectos-how-can-i-found-it-in-a-yunk-yard.794080/post-7996098
