Topic: Need some help..... (Read 1904 times) previous topic - next topic
Need some help.....
Can someone tell me what was supposed to go through these holes in the firewall? 85 turbo coupe. Been working on the dash and wiring and can’t seem to find anything to go through them, I think I maybe forgot to weld them closed.
Re: Need some help.....
On my '85 XR-7, the one on the left had a plug in it and the one on the right is a vacuum line for the HVAC blend door actuator (I think).
One of 1,246 built
Thank you very much. I will have to buy some body plugs for those holes I guess. I sort of recall a vacuum dump switch on the brake pedal and was thinking maybe that was one of the holes, I think all the hvac stuff gets its vacuum from over by where the heater core comes through. Regardless I can plug both holes and not worry that a chassis electrical harness is missing.
I realize this is way late but just to confirm the vacuum dump switch on the break pedal was to cancel the cruise control when the brakes were applied if memory serves me correct and yes the HVAC vacuum is brought in over by the heater core comes through.
