Topic: Starting fresh (Read 67516 times) previous topic - next topic
Re: Starting fresh
Reply #150
What intake you thinking of going with?
Re: Starting fresh
Reply #151
Trick flow R series like this one
Re: Starting fresh
Reply #152
Ah. Probably a good choice. Should run pretty well. I was hoping you were thinking about a Performer RPM level intake minimum.
Re: Starting fresh
Reply #153
Nah I want outside the box. Something different.
It'll make good power and still keep fairly mild street manners with the fitech kit
Re: Starting fresh
Reply #154
The R isn't that out of the box, and a good choice with the gearing. I was just hoping you weren't going with a Performer or Stealth intake for the "low RPM torque"  ::)
Re: Starting fresh
Reply #155
Yeah. Made that mistake before on other projects
Re: Starting fresh
Reply #156
Some demo day progress. Getting closer to yanking the old 302 and aod. I'll get it pulled tuck the wiring clean up the engine bay throw some paint at it and by then it'll be ready for the new combo
Re: Starting fresh
Reply #157
Well now the tough stuff is done, time to do some clean up and prep for the new iron and all the goodies I've been stocking up on all summer long.
Re: Starting fresh
Reply #158
More prepping and side tracking. Decided today that it would be a good time to swap the doors fenders and all the other nonsense work I had to do before plugging the new drivetrain in. Also tucking the wiring like I did on the old one. Tried out that vht wrinkle finish paint on the air cleaner and valve covers just to see how it looked. And I like it. Looks a lot better than chrome and really old aluminum
Re: Starting fresh
Reply #159
I like the progress and thumbs up on the valve covers.
Re: Starting fresh
Reply #160
I'm getting somewhere now. It should be ready to go in as soon as the bay is ready for it. Still a few small things to do to that area then change the rear main, bolt the t5 and all its glory to the old girl and send it.
Edit: for the record I hate those stupid t-less t-handle valve cover fasteners and they will be going in the garbage can soon.
Re: Starting fresh
Reply #161
Looks like it's coming along. Hopefully be able to fire it up soon.
Re: Starting fresh
Reply #162
She's in. Just gotta get the transmission in and button up the under side then I can focus on the top side and the hood cause a flat one simply wont work due to a minor clearance issue.
Re: Starting fresh
Reply #163
Just slam the hood hard a couple times. It'll close.
 :toothless:
Re: Starting fresh
Reply #164
 :toothless:
.....sooner or later.
Transmission and shifter are in. Clutch cable in and roughly adjusted the firewall adjuster will do the rest I'm sure. I've got to finish up the exhaust, and put the driveshaft in and fill the t5.
Then the work up top can be started on some wiring. That itself will take the longest for me but its a labor of love.
