Topic: Automatic shoulder belt track noise..... (Read 2151 times) previous topic - next topic
My thunderbird has the automatic shoulder strap belt and it makes a ton of noise openining and closing. i think maybe if i lube up the track it might fix it but i dont know how to do it. Should i just spray some wd-40 all over the track or will it hurt somthing, or do i need to take it apart to lube it up?? Thanks
Re: Automatic shoulder belt track noise.....
Two things should help fix this, a finger... and some white lithium grease. Less messy than wd-40, and it should last longer.
I second that white lithium grease. it almost never wants to come off and that is what I used on my tempo when it had the same noise and that took care of it. You can also get  white lithium in a spray form.
i have some white silicone grease, will that work also?
That should work good also.
cool thanks for the help
