Topic: Changing coolant in 1987 3.8V6 CFI engine... (Read 3535 times) previous topic - next topic
I put the tee on the outlet hose [the hose you highlighted in red]. It shouldn't make a difference where you put it.
Yes, it is good that AC comes on when on defrost.  The AC is designed to dry the air when attempting to defrost.  If you want heat but do not want AC to come on, leave lever on VENT and turn heat up.  That is, AC is designed to come on when heating or cooling.
Quote from: JeremyB
Does it release all trapped air up to the intake manifold when refilling? Hope it will work this way?
