Topic: I “flocked” my sun shade (Read 2893 times) previous topic - next topic
I recently stripped my messed up sunroof shade and re-flocked it with material I got here: https://www.flockit.com
It was a tedious job, but it came out nice.
1988 T/C body with a 5.0 transplant. Motor has a Vortech V-2 supercharger, Edlebrock Performer RPM II intake, heads, FRPP F-303 cam, Comp Cams roller rockers, Power Pipe, LMAF, full Mac exhaust, lowered, Koni's, 5 lug conversion, Cobra wheels, 13" Cobra brakes, etc.
SOLD September 2020. Will miss this car after 19 years of building/driving/showing it off. Time for a new chapter in my life.
Dynoed 446 horse/409 torque at the wheels.
2003 Tenth Anniversary Cobra Convertible. 1 of 369 Torch Red made.
2021 Chevrolet 3500 dually, crew cab Duramax.
That turned out really well.
Pretty flocking nice! ;)
It's always bugged me that the factory shades always looked like  after just a few years. This is a great restoration solution. Thank you for sharing!
This actually exists! Wow, now I can fix up the salvage yard one I bought. Thanks for sharing :D
With my car, the arm rests and the door pockets are kinda sticky. Like the red vinyl is sticky. Wonder if this could be good alternative?
Quote from: kylesburrell;466855
Have you tried Simple Green or warm water with Dawn dish soap using a Scotchbrite pad? This should help some followed up by a vinyl treatment from a reputable company like Meguiars. Sorry to hi-jack...
 S O L D
Quote from: ISTLCRUZ;466856
Ive tried simple green, it worked for a little while. Thats what I normally use to detail/clean interior bits. I think I had better luck with Goo-Gone. But clearly neither has permanently remedied the problem.
