Topic: LED Bulb Conversion (Whole Car) (Read 71490 times) previous topic - next topic
So I got this idea to convert my '84 Cougar over to LED. It didn't need the conversion but I simply wanted to see if it could be done successfully. Over the years I'd seen various scattered reports of people attempting it, with mixed results, and I thought, "It's 2018, this should be a no-brainer."
Well, I dove right in and through a lot of trial and error, I made a game plan that so far is working great.
First my rules for myself (because I'm a stickler for details):
- Everything has to appear stock as much as possible.
- ALL lights get changed. Every single one in the entire car. It's all or nothing.
- If possible, keep the stock light range (~4500K).
- Make sure I can switch back to stock incandescent bulbs in the future if I want.
- All bulbs should remain dimmable if they were originally set up that way.
I am failing at that third one, because even though there are a lot of bulbs to choose from, most seem to be in the 6000K light range which puts out a whiter-to-blue light pattern. Which is fine, don't get me wrong, but not what I really really wanted.
But everything else is good so far.
I'm quickly finding out what works and what doesn't. I've got a few hundred dollars' worth of unused bulbs laying around doing nothing, because they didn't work for one reason or another. I've bought several packages of fuses due to some unexpected blowouts. And I've got a bucket full of the original bulbs from the car...and when I say 'original', I mean FROM 1984. It's possible that none of them had ever been changed!
Anyway...I'm going to post progress photos here as I get them. The car is dirty and I need to get it a little more presentable for photos. It's also very difficult to photograph this.
But I started with the dash bulbs, which are notoriously dim in 1983-84 dashes. They are 194 bulbs in the 6K range and are dimmable. See photos below...
I have an LED bulb kit for the gauge cluster that I bought 18 months ago. I may hook those up this weekend.
Got some fresh pix...these are unfiltered, no color correction, right out of my phone camera.
Clock and heater panel:
Clock:
Heater panel:
Cluster illumination:
Closer view of the cluster:
Dome light:
Footwell light, passenger side:
I never knew the dome light was even a bit clear...
I had an 84 LTD (fox) who's cluster was lit the same way (dim), and I swapped the 194's for 168's and was completely satisfied with it.  Of course, it was 1999 and LEDs weren't a thing...
Those small wedge base LEDs CAN be had in warmer, more original colors.
WOW!!! Sure makes the factory lighting look primitive. LOL.
I should get on this. I'm pretty sure 99% of the interior bulbs on my car are 30 year old factory bulbs. Plus LEDs will put less of a load on the charging system.
I put LEDs in my digital cluster. Totally would recommend, cuz the old bulbs, in direct sunlight you couldn't really see the display.
Yes!!!! I love this.
Converted most of my bulbs to LED a few years ago. Never got around to finishing the whole car although that was the whole idea. The 30-something 194 bulbs in the 87-88 cluster threw me off for a while. I got some cheap ones on ebay 7 or 8 years or so ago, they were total garbage, so bad it made by stock bulbs look good...
It was a great upgrade that really helped the car feel (a bit) more modern.
Quote from: sarjxxx
BINGO. That's the problem I had with a lot of them...the eBay bulbs would either be too dim, or not put out the correct light pattern for a 168/194. And those are the majority of the interior bulbs, plus several on the exterior. They've gotta be right or else they're just not usable at all.
So the down-low is...you get what you pay for. Every worthwhile LED bulb cost in the neighborhood of $9 US each. And that's alotta cheedah. But for a quality name brand that is super bright and puts out the correct lighting pattern, it's worth every penny. I doubt any of these bulbs will die in my lifetime.
Quote from: Haystack
I have some resources... ;)
Quote from: thunderjet302
It's for people like yourself that I'm sharing this info here. You will definitely appreciate it and undoubtedly enjoy doing the conversion. Like I said, it's a little expensive, but I really did enjoy going to every AutoZone, Advance Auto, and O'Reilleys in the area to hunt down all the bulbs, several at a time. It was the sense of accomplishment that made it all worth it.
How hard is it to remove the dash cluster to replace the bulbs in an 84?
Quote from: QUICKSHIFT;465750
Ummm...I'm not gonna sugar coat it...it's not real fun. Worst part is disconnecting the headlamp switch  and the speedo cable. Amazingly, Ford actually planned for that and there's enough room to get your hand in the proper spots to reach everything. But it's still no picnic.
Once those are done, though, and the dash trim panel is removed, it's easy enough to get to the cluster. I never removed mine completely, just reached the illumination bulb holders and swapped out bulbs. One thing about LED bulbs is that you have to test them before putting things back together. The bulbs sometimes won't light up in one direction...you have to remove it, flip it around, then it should work fine. But you have to test all that before putting the dash cluster back in. Trust me on that. ;)
More fresh photos...
Dome light with map lights:
Console:
Front side marker:
Front marker:
Both front markers together:
Rear license plate lamp:
Taillamp:
I defy you to swap the glove box light. I tried twice and fried two led bulbs! :punchballs:
Just two bulbs in the dash cluster?
