Topic: 7.5" axles into an 8.8"? (Read 6137 times) previous topic - next topic
The HOUSING on your 84 is the same width as the Mustang 8.8. The axles are longer on the TBirds/Cougars. Pull the axles and brakes from your 84 Tbird and swap the whole thing over to the 8.8.
It's possible that you can just use the axles and drums from your TBird. It's been a LOOOONG time since I messed with this swap and I don't recall if the backing plates are the same between the two, or not. The extra 3/4" is made up in the backing plates or the drums.
Thanks Chuck. That's going to be tonight's project.
Quote from: 1wld brd;465215
it's a complete mustang differential so....  Ya it has the mustang axles and drums.  But that is what the question was.  I can swap the 7.5 axles and brakes onto it and get my width back right?
yes.
If the brakes are the finned, 9 inch version, yes, direct swap.
It's when you do the ten inch swap like I did that things get really wonky...
So I guess it's a good thing I was finally doing this swap anyways as the 7.5 was definitely showing signs it was ready to die and I'm sure the punishment the 6.0L was going to give it would have finished it off
X
X
The pin is actually stuck there.  I had to take a hammer and punch and pound it that far to get the axles in
I shattered the pinion bearing on the 7.5 in my car when I launched it (with the same engine/trans combo it currently has). Pinion was slapping into the carrier housing making a nasty racket. https://www.youtube.com/watch?v=4xzkctodX0E
Hence why I finally built and installed that 8.8....
Ya I have broke 4 of those 7.5s behind my stock 302 in that blue cougar I had years ago. Lol. And same thing.  Carrier caps fragmented
For anyone curious on the difference between the mustang and the TBird here is a pic of the only difference.  TBird is on the right
 X
Yeah, we have the lengths of those axles listed in a stickied post here.
I *think* that 3/4" difference in length is made up in the drum height. You might post up a comparo of the drums, if you get around to it.
Yup. Difference is made up in the drums.  Changed the backing plates even though they are the same.  Gave me a chance to clean them and paint them.
X
Stick out from fender comparison.
Tbird axle :
X
Mustang axle:
X
