Topic: Best aftermarket oil/temp/tach/etc. gauges (Read 2389 times) previous topic - next topic
Hey guys, hope all is well.
What brand of aftermarket digital gauges are you guys running? I will most likely be buying a few within the next few months. I want to make sure I get the best bang for buck, I've had too much bad luck with cheap shiznit lately :hick:
Thanks guys!
'88 Thunderbird LX
Engine:  FR B303 cam, GT40P heads w/ Trickflow valve springs, Explorer upper/lower intake, SR cold air intake w/ MAF
Exhaust:  shorty headers, BBK O-R X-pipe, glasspacks w/ turn downs
Misc:  8.8 rear, Saleen SC replicas 17x8/17x10, Mach 1 front springs/SN95 rear springs
'74 F100 Custom 351W
Autometer is good, from my experience.
I built a cluster for my Turbo Coupe using all Auto Meter gauges. Have the GPS unit for my speedometer. Look and work great.
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
I'd love to see a pic of that^^
I'm thinking of going full aftermarket on the gauges on my 87 T as well, I'd love to see other's setups.
Autometer in the Bird, Autometer in the Coupe, and the F100 will also have Autometer.  Their custom shop is awesome.  I want vintage type gauges for my F100 and the ones I like are 3 1/8" diameter for the GPS speedo and tach.  The problem is the speedo only went to 120 mph and the tach was only showing 7K.  They asked if I could go 3 3/8" diameter versus the 3 1/8" and if I could they could make a 140 mph speedo and a 10K tach and even sent mock ups of what they would look like.  I am sold so now to start saving the $$$.
In that picture I have a warped bezel on the left side. Looks better with the new bezel installed.
