Topic: Oil Leak - Ideas? (Read 12015 times) previous topic - next topic
Oil Leak - Ideas?
When I had a similar problem  several years ago, it turned out I had screwed up the valve cover gasket replacement on the passenger side.
Since I had just replaced it I was sure that couldn't be the problem.
Oil Leak - Ideas?
Quote from: softtouch;464298
Thanks. I suppose thats possible too but I replaced it 3 times in total and during the third time, i couldnt see evidence that it had been leaking.  I used both the felpro cork, then the rubber gaskets and returned to cork.
Oil Leak - Ideas?
Can someone remind me, does the intake seal sit on top of the intake gaskets that sit bw the head and intake manifold?
Thanks
Oil Leak - Ideas?
Also, anyone know the easiest way to plug the air pump pipe sleeve on the y pipe if I remove the air pump?  I did this 20 years ago on my former 84 cougar but had a friend weld a bolt on, but have no access to welder these days.
Thanks again.
Oil Leak - Ideas?
anyone recall the size wrench needed to remove that air pump valve threaded into the intake manifold ??  Trying to get to those intake bolts underneath it.
thanks
Oil Leak - Ideas?
Do not use the cork gaskets on the ends of the lower intake.  Use a large bead of silicone on the ends of the lifter valley and let them skin up before you install the intake. I have seen more mistakes and leaks using the cork gaskets than anything else.
Oil Leak - Ideas?
I've had great luck with Fel-Pro Permadry Plus (the blue rubber end seals).  RTV as an end seal works best with HD grey Permatex RTV, or the small caulk tube of Motorcraft Grey RTV from the dealer parts dept.
Oil Leak - Ideas?
Reply #39
Hey all. If i wanted to swap in a carbbed 5.0, would this require alot of fabrication work??  Seems i could bypass electrical issues with a carbed motor.  Im thinking about this more and realize that Im borer with this 3.8 and maybe a change to a better motor would be good.
Thanks
Oil Leak - Ideas?
Reply #41
Quote from: TheFoeYouKnow;464326
To start with, you'd be in the market for a transmission that would bolt up to a 5.0.
The 5.0/302/289(from '65)/255/351C&W/240/250/300/3.8/4.2 all share the same bellhousing bolt pattern... Also the early 4.6('91 to mid '92) and a few 400 used same pattern... Anything with a AOD trans is same, as there is only one bolt pattern for those trans(early mod motors used AOD, I had one)... The OP should have a C5, AFAIK those all have the small block pattern...
BTW the balance on 6cyl is different than v8 so although the transmission bolts up, would need correct flexplate for swapped engine...
Usually the 6cyl versions are built to a lighter duty standard, so a high milage unit may not be up to v8 duty(at least for long)...
Oil Leak - Ideas?
Reply #42
Thanks. What cars would be best to get a 5.0 from?
Oil Leak - Ideas?
Reply #43
I had a 5.0 to start with, but when I had to rebuild, I found it was cheaper to get a complete explorer engine with low miles than to rebuild and buy the heads and intake from the same, but that's the beginning of a much longer story.
Oil Leak - Ideas?
Reply #44
What about accesory brackets, etc? Would explorer still be a good engine to get??
