Topic: AOD floor shifter gear lock release button (Read 4661 times) previous topic - next topic
My '88 XR-7 floor shifter gradually stopped moving from park to N/D/R due to the loss of function in the release button on the side of the shifter.  I had to fight with it at the end before it finally quit working. I disassembled the shifter and found that the part that transmits the pressure on the button to the latch release in the base of the shifter (through the shifter stalk) had worn out and broken.  This piece is basically a solid plastic tube with a bunch of round nubs along the length of it. Does anybody know what I'm talking about?  Is there a replacement for this piece?  For now, I've removed the latch and spring at the shifter lock, but now the vehicle can be put into gear or neutral without the key and by accidentally bumping the shift lever.
Any input/help would be appreciated.  Thanks in advance.
If you can find a part number for that little white ball piece these guys might have it: http://www.greensalescompany.com/
One of these days I am gonna get with my dad and see if he can help me print one on a 3d printer. Could probably sell them cheap if they worked okay.
Quote from: Haystack;463222
I have a complete floor shifter set up at home, and a 3D printer at work. I should really try this.
My concern is that, even in ABS, it may not be as strong as the factory part. You would have to use a lot of infill when printing it.
I'd be willing to be your test dummy if you want to try to make one or more.  Since I know how to work around the failure of this part, it wouldn't be a tragedy if it didn't last.  They're somewhat flexible, I don't know how rigid the 3D printed piece would be, so that would be another thing to consider in addition to the strength question.  Keep us posted!
I saw thunderjet302's comment before yours.  I would definitely be willing to try one, and I would expect there to be a market for these, even if not a large one.
Quote from: thunderjet302;463218
I've been searching and can't come up with a parts diagram for our cars.  Any leads on where to find a resource for the info?
The part number is E7SZ-7E148-A. Quick check of eBay and Green Sales didn't yield anything. Hope that helps though.
shop manuals will show the actual part.
Quote from: CatManDude;463241
Depending on the amount of in fill a 3D part can be pretty stiff or flexible. I'll have to pull the shifter I have apart and get a feel for what it should be like.
Recreating the thing without a 3D scanner is going to be fun :hick:
Wouldn't be bad to recreate it. You could just put some beads around a square or even round tube and duplicate it nearly identical. Its a plastic rod, really doesnt have to be nore complicated then that.
Thanks!
If you can find one, use it. I've been busy at work and trying to hire another employee so I don't know when I'd have time to try and make this thing, at least any time soon.
Ill give my dad a spare one ive been saving and see what he says. He is all self taught and has built about 10 3d printers now, first couple he soldered the boards and bought all the parts at the hardware store.
