Topic: 5.0 idling at 800-1000, never been able to fix it (Read 5301 times) previous topic - next topic
Quote from: TheFoeYouKnow;465133
There's always THIS.
Well that looks like a cheap/easy enough fix. Power, ground, and splice into the tach signal to the factory tachometer. I might have to pick this thing up. Based on prior testing I'm *pretty sure* that the stock digital tachometer is set up for a V6, even in V8 applications.
I'm going to try and pick it up over the summer and then run it and the Autometer tachometer at the same time to see how accurate it can make the stock digital tachometer.
I dunno, $89 plus tax and shipping plus the install, that's nearly 1/4 the value of the car.
Quote from: Haystack;465139
It might be too expensive a proposition for some cars :hick:
Quote from: thunderjet302;465140
 true but if I can get 90% of the value for 10% of the cost why not?
