Topic: 95 HO into 88 V6 T-bird (Read 5631 times) previous topic - next topic
Hey guys I thought I'd start a new thread with some of the issues that I'm having with my engine swap. I have the engine in the car with all the connections hooked up. I have an engine harness from an 87 5.0 cougar trying to match to the body of an 88 V6. The connections don't match very well, and I need some input on what I need to do from here. If anyone is familiar with which wires to hookup or leave disconnected, please let me know.
Quote from: LastThunderfox;462601
Should be color for color...
AFAIK, there is no reason to leave anything disconnected... Some things would be deleted on a Turbo Coupe...
BTW the '88 5.0 harness is plug & play for install into a '88 3.8, there are several differences in '87 to '88...
I'm seeing a couple connectors that need adjusted. Please correct me if I'm wrong-
1) there are the black and grey connectors by the brake booster (every one needs repinned). There are also 2 single wire connectors as well, don't know if I should ignore them (white/red and black/orange)
2) the grey rectangular connector under the coil (found that the oil and temp wires are in this one today)
3) the connector next to the ecu has matching wires apart from the body having an extra pink/black wire
I got the 87 harness because that is what I was able to find in the junkyards near me. I didn't see the differences until I started hooking things up.
The v-6 harness might actually be a closer match then the 87 v-8.
Quote from: Haystack;462605
C'omon, a batch fire V6 isn't going to be closer than any SEFI 5.0 harness... Well maybe the OBD-II version in my '96 F-150...
All right, this is what I came up with, please correct me if I'm wrong-
Oil pressure - white / red
Temperature - red/ white
Ground- black
Pin 30- brown/ White
Pin 46- black /white
Pin 17 tan
Tach- Dgreen /yellow
A/C green /purple
O2- grey/yellow
Start- red/blue
Vpwr/Run- black /yellowmolested and red/green
Vss+ Dgreen/white- needs added to harness (in grey connector )
Vss- orange /yellow -needs added to harness (in grey connector)
(The stand alone connectors seem to be left unconnected)
Pin 19 (fuel pump check)- pink/black
Well, I test drove it tonight. Everything seems to be working. I didn't do anything with the black /white Pin 46, I just wired it like I posted previously. I did hook up my starter neutral safety switch by connecting the two wires (red/blue, white/pink) at the transmission, then splicing my clutch pedal switch into the white /pink wire behind the climate control. So now, I'm going to try to go to the UMTR race this Sunday, and hope for low 15s
