Topic: Inner Tie Rod Ends Shot on Wonderbird (Read 1857 times) previous topic - next topic
I suppose I should have expected it. Had the front wheel off experimenting with various spacers and felt some play in the steering. Sure enough, inner tie rod ends are shot. I decided to take the opportunity and change the ratio with a turbo coupe rack & pinion vs. just changing the inner tie rods. The 140K rack also seeps fluid so it makes $$ sense to change it all out, including the outer tie rod ends. My new SN95 struts and springs are in my shop also, so it looks like a new front end if I throw in the lower ball joints on top of it all.
Will I need the MM adjustable camber plates with the SN95 springs??
1986 Thunderbird Elan 5.0 EFI AOD, 3.73:1 SN95 rear, 17" Mustang Bullitts w/Firestone WO Indy 500's. Future plan: 349 stroker, C9 block, forged dish pistons, Scat 9000 crank, 4340 I beam rods, ARP head/main studs, ported explorer intake, 1.72 CC RR, Vortech V2 supercharger, Mr. Freeze Meth Inj, intercooler, TFS 190 11R CNC heads (66CC), BBK shorties with 2.5" duals, 4R70W Transmission, Taurus fan.
I've got 98 Mustang GT springs in the front of my car. Dropped the nose about an inch. Still aligned in spec without caster/camber plates.
Quote from: thunderjet302;462226
Good to know. I spent a lot of $$ on all of those front end parts and have to get ready for my HO conversion. I'm really not disappointed, as 140K was around the time most 80's Fords needed serious front end work. Actually, the Taurus's needed it a lot sooner on the average.
