Topic: SN 95 8.8 Swap into 86 Elan, E Brake Cables? (Read 2125 times) previous topic - next topic
I'm swapping a 3.73 8.8 rear out of an SN 95 Mustang into my 86 Elan. The original 7.5 has drum brakes, whereas the 8.8 has disks.
Can anyone suggest what E Brake cables to use with this swap?
1986 Thunderbird Elan 5.0 EFI AOD, 3.73:1 SN95 rear, 17" Mustang Bullitts w/Firestone WO Indy 500's. Future plan: 349 stroker, C9 block, forged dish pistons, Scat 9000 crank, 4340 I beam rods, ARP head/main studs, ported explorer intake, 1.72 CC RR, Vortech V2 supercharger, Mr. Freeze Meth Inj, intercooler, TFS 190 11R CNC heads (66CC), BBK shorties with 2.5" duals, 4R70W Transmission, Taurus fan.
think you want lincoln mark 7 parking brake cables. Mine are AC Delco, cost about $15 each
The Turbo Coupe brake cables work pretty good as well.  At least that is what I am using with the SN95 Cobra rear setup on my Bird.  My cables were kinda suspect so I replaced them from the foot brake pedal all the way back.
Thanks. Its always the little details that make or break a swap.
