Topic: electronic instrumentation recalibration (Read 6972 times) previous topic - next topic
In any case, it's machined into the output shaft, so there is no way to correct it with a gear change.  23 is as far as available gears go, and the math tells me I need 24.  I could reduce my error with a 23, but I'm told they don't hold up.
Ran into a problem when I rebuilt my dash using Autometer gauges. Couldn't get my speedometer to read right. Went through the calibration procedure at least a dozen times. Replaced the VSS and used a Steeda 23T gear. Ran out of patience. Finally ended up installing the Autometer GPS for the speedometer- end of problem.
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
I varried my speedo by 11% by getting real tires. 275/60/r15. Easy overdrive adder mod.
Quote from: TheFoeYouKnow;460991
My AOD has the 8 tooth output shaft. I've been running a 23 tooth driven gear for years without issue (the black one Late Model Restoration sells). I plan on swapping a 21 tooth back in and running the FRPP speedometer correction box at some point, but it hasn't been high on my list of things to do as of yet.
