Topic: motor not starting (Read 1027 times) previous topic - next topic
motor not starting
yeah i had put in a new starter relay because i broke the last one now my car wont start. all the electrics come on but no respons from the starter. Any help ?
Re: motor not starting
Have you checked to see if there is power on the starter when the ign is turned to the start(crank) position. Also you can check for power on the red/blue wire on the solenoid, again with the switch in crank position...
That's assuming you remembered to plug the little rubber-hooded wire onto the new solenoid, and on the right terminal (some have two).  I assume the starter spins if you "jump" the two big terminals on the solenoid with a screwdriver?
Death awaits you all with nasty, big, pointy teeth.
1988 5.0 Bird, mostly stock, partly not, now gone to T-Bird heaven.
1990 Volvo 740GL. 114 tire-shredding horsies, baby!
umm ok ... yeah all i did to the car was remove the starter relay thats it, i really dont know much about cars motors and stuff
