Topic: The Offical 2017 Drag Strip Thead. (Read 12949 times) previous topic - next topic
Ran the bird again last night at the local TnT.
Temp was 90 degrees with DA around 5900-6000.
First run, ran a new best with no spray. Went 10.14@134.
Second run, put the bottle in the car hoping for a new best. Went 9.86@136. Good but not good enough.
Third pass, dropped tires from 10.5psi to 10.2 and loosened the rear shocks one click. I also hit the nitrous as soon as I released the brake instead of waiting a split second after TB release.
New best: 9.76@138 with a 1.41 60'
The brand new Hoosier's definitely helped.
I noticed on the video the car seemed jump up more than forward so I may have the IC a little too far back. I will readjust the rear lower control arms for the next track assault and see if it will 60' a little better.
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
Dayum Chicken, that cookin'... :bowdown:  Congrats...
Quote from: Pressure cooked chicken;460536
Wow, that is impressive!
Thats awesome!!
Brian R.
88 2.3t Ranger
Took the bird out to TnT again last night.
Made three runs, all with the nitrous.
First run with 11psi in the tires, it had a little trouble hooking but still went 9.81@138 with a 1.43 60'.
Second run tried short shifting (7200 instead of the usual 7700-7900) to see what would happen. With 10.5psi in tires it went 9.95@135 with a 1.40 60'. New best 60' but the short shifting was a no no.
Third run dropped tires to 10.0 psi and shifted back up where I normally do. Ran 9.79@137 with a 1.39 60'. Finally got this puppy in the 1.3X 60'!
10psi in the tires is as low as I have run them. Seems too low but it hooks and doesn't have any top end dancing around so I dunno. Still would like to get the suspension to where it would hook as good with more tire pressure.
TC#3- parts car
Wow that thing is moving!
Brian R.
88 2.3t Ranger
Soooo where is this list at?? I finally have some times worth posting.
yesterdays best was a 1.65 12.42 @ 110.7
Brian R.
88 2.3t Ranger
