Topic: Why NOT to use boxed rear UCA on the street. (Read 6128 times) previous topic - next topic
What lowers are you running?
Between the Maximum Motorsports lowers, stock uppers, and quad shocks I've got no wheel hop.
....boxed with poly bushings. Could be the quads are shot.
Interesting.  The quad shockshiznit the trash can the minute I installed the Maximum Motorsport lowers on my Couple.  Never had wheel hop after that and never put a set back on the car.  Some guys have removed them and then put them back on as they would still get a little wheel hop.  That was usually cured with good rear shocks and/or installing new UCA bushings.
I just wanted to clarify that by good rear shocks I do not mean stock replacements which is an issue for our cars as none of the quality damper company that I know of build rear shock for our cars.  I ended up getting a set of Chuck's rear shock adapters so I could run SN95 Mustang rear shock on my Bird.
These are the only "performance" rear shocks that fit our cars with out Chuck's bracket: http://www.oreillyauto.com/site/c/detail/KYB4/KG5556/03415.oap?year=1987&make=Ford&model=Thunderbird&vi=1140253&ck=Search_C0077_1140253_3405&pt=C0077&ppt=C0035#compatibilityTab_
I had a set waaaay back in the day and they are a really good stock replacement. They are not valves for anything more than that. Much better than the Monroe's and other offerings for sure if performance is what a person is looking for.
I had CHE arms and solid bushings (axle) and it was ed harsh. The slightest bump in the road would  "toss" it about...torque steer? Oh hell yeah...even with no throttle input, were the road rough enough. Maybe not torque steer, exactly....but....yeah.
Rubber and stock, are best for all but the most dedicated track only cars.
Oh man, I F'd up and put poly's on the axle side of the uppers in my '85 TC one time and that was a huge mistake.  Rubber bushings went back in the next weekend and those six or so days were just miserable.  I still have rubber bushings on the axle side of the UCA's on my '83 but have spherical ends on the body side like the lowers.  It is definitely not quite but I am not giving up the performance.
Oh yeah lol.
When I did the rear in my notch I made ed sure to put (new) rubber in the axle ends. The little I drove it before I did the engine swap it felt more supple, but also quieter yet more responsive without the "washboard oversteer" that my sport had.
Never again. solid or poly axle bushings are just too ed much for a mostly street (let alone 6 miles of gravel roads) car..if you live in an area where the extent of the county road funding goes to widening bridges for the bigger trucks, tractors and combines, rather than crowning, gravelling, and maintaining the roads...hell, maybe I need to buy a horse. My luck, jesse james would steal him...
Yeah, poly sucks for the road. Track use, it's probably needed, though.
If ploys were legit for daily driving then my F150 would have them in the front control arms and in the rear leaf spring bushings...ha ha ha!!!
Spherical bushings/bearings ftw!
Finally took the Cougar out for a decent cruise today with the wife, and she noticed how well it rode. This was with the poly bushings in the boxed LCAs and axle end in the uppers which I removed the "boxing" plate from. So far so good.
