Topic: 5.0 EFI Engine Harness Wiring Question (Read 6676 times) previous topic - next topic
From the 85 EVTM:
The 4 pin connector for the 3.8L V6 idle speed control motor wires are:
BK/W (signal return for the EEC sensors)
Y/BK
W/LB
LG/W
Does this match your "female" connector?
He said the connector was on the 86 ecu harness... i have one in the shop, and there is no connector like that on mine... I couldn't even find those wires on the harness and
Hoping a few more pictures may help to clarify.  The engine computer harness leading from the computer, through the firewall, runs across the length of the firewall from the passenger side of the car to the driver's side.  This particular harness is out of a 1986 Cougar EFI 5.0 car, I think this harness was a one off for this year and was then slightly modified for the 87/88 cars.
As you follow the harness to the driver's side, it terminates at several different connectors that mate to the chassis harness behind the black plastic cover around the stater solenoid and ignition coil.  In my photos, I have the wires exposed and pulled out of the loom due to trying to find where the loose black wire goes.  The connector in question has a red arrow on it in the last pic.
I dont have that connector on any of my harnesses
Quote from: daminc;459308
So ... the plot thickens ... thanks for taking a look!
Well, I was able to answer my own question to some degree.  Managed to find another '86 5.0L EFI Cougar that was relatively new to a somewhat "local" UPull It yard.  So ... I pulled myself a spare engine harness ... and ... it has the exact same connector with a black wire that goes nowhere.
was it plugged into anything? or does it look like it was?
It was plugged into the corresponding 4 pin connector, but that particular wire did not lead anywhere.  It doesn't appear that it ever did either.  It looks just like mine ... same length and a clean cut/termination like someone just cut it with a pair of cutters.  I decided to just shrink wrap the end of mine and then tape it to the other wires running to that connector ... just odd as there is a wire in the corresponding connector and you'd figured they wouldn't bother putting a wire in if it wasn't going to lead to anything.
