Topic: Wheel fitment (Read 2000 times) previous topic - next topic
Wheel fitment
Would a 17x7 wheel with a +38 offset fit an 88 cougar?
88 Cougar
88 T-Bird
other cars that don't apply to this forum
Wheel fitment
To each there own but why such a skinny wheel? Not positive but I would think they would fit, mine are 17x9's with 20mm in front
Wheel fitment
Well it's a few things I like the look of steel wheels the wheels I'm looking at are cheap and I need tires for the car to pass inspection the roh zr6 16x8 that are on it don't quite fit right and I'm broke it looks like from the calculators online that I will need a small spacer
88 Cougar
88 T-Bird
Wheel fitment
As an added question what the lowest offset you can run without sticking out too far or getting fender scrub?  I have been eyeing some +12 offset rims
Northwest Truck series at iRacing every Thursday at 9pm Pacific
Wheel fitment
Go here to compare offset and backspacing with different rims and tires:
https://www.rimsntires.com/specspro.jsp
