Topic: No heat question (Read 11271 times) previous topic - next topic
No heat question
Quote from: AlabamaWildman;458348
Question:
Does anyone know about the possibility of "Looking Thru" the side of that HVAC Duct ?
... using an Inspection Camera (ala Harbor Freight) and Drilling a Hole only Large enough to allow the camera access ??
without the need of removing the Dashboard ??
there is a snorkel access under the plastic cowl screen / cover on the passanger side.  pop the hood and remove wiper arm screen cowl cover.  its very outboard so to speak.  the opening is oval and about 3'' x 2''
or....
you can possibly enter through the floor duct openings,,
or......
remove the dash covering and go into any one of the dash vents
never used a camera system though.
No heat question
Thank You, Sir !!
No heat question
You could pull out the blower motor resisters. Looks like they are down wind from the AC evaporator.
Turn the ignition off and:
DO NOT RUN THE BLOWER WITH THE RESISTERS PULLED OUT OF THE AIR BOX!! The resisters will over heat and may blow the thermal limiter.
No heat question
Thanks !! !!
No heat question
if it does thermal, then a small hair of 26ga single strand of copper soldered in place would be the new fuse.  the limiters simply blow like a fuse anyway.
No heat question
Quote from: jcassity;458358
if it does thermal, then a small hair of 26ga single strand of copper soldered in place would be the new fuse.  The limiters simply blow like a fuse anyway.
Wrong, the limiter will blow with the normal amount current draw if the air flow is not moving the resister heat away from the limiter.
No heat question
Thanks !!
I do not believe this one has any type of "Thermal Imagine"... wish it did
This is only a very small Video Camera
No heat question
Quote from: softtouch;458353
You can run it on high though, right?
No heat question
Quote from: JeremyB;458367
Yes
No heat question
Reply #39
Quote from: softtouch;458361
we are saying the same thing,, when there is a air mover fault the limiter will blow..  thats why the call out for 26awg or smaller to do a make shift repair
