Topic: picked up a decent 1984 5.0L Thunderbird (Read 19918 times) previous topic - next topic
Summit delivery showed up.  Trick flow heads and cam. Comp cams pro magnum rockers and new timing chain and edelbrock rpm intake. Plus the gaskets and ARP bolts and mechanical fuel pump and AN fittings and braided stainless line to convert to carb
Nice!
Brian R.
88 2.3t Ranger
Quote from: 1WLD BRD;456531
Is that going on the 302 in the car or the 351?
Edit: Never-mind the Performer RPM 7121 is for 289-302s. I answered my own question :hick:.
Lol yup.  Will finish getting what I need over winter to build the 351. For now will enjoy it with a mild 302
What rear wing is that? Looks nice on there.
1985 Muscle Car V8 Thunderbird
tbirdregistry.com - #56919
Lorain, OH. Assembly #151041
811 TBirds followed Mine
1988 Thunderbird V6
tbirdregistry.com - #80084
Lorain, OH. Assembly #111106
I think it is the Ford motorsport wing
Mocked up the engine after I checked PtoV clearance.  Can't wait to finish assembling this thing and drop it in.
Got some work done this weekend.  Pulled the engine out.
Got the heads torqued, rockers adjusted, valve covers modified to clear.  Intake on.  Cut open the timing cover for a mechanical fuel pump.  Bolted on the headers.
And dropped it in and bolted up the torque convertor and bell housing.
Can't wait to drive this thing again.
What did you use for a torque converter?
T-Birds can't fly.  Ask how I know...
Make it go vroom soon.
Just the stock torque converter. Planning to go manual soon anyways. Ordering a new water pump today and a Lokar kick down cable.
Got it running last night.  Rockers are tapping g on the valve covers though so had to shut it down instantly.
EDIT.  that wasn't the sound.  Turns out it was my mechanical fuel pump making the sound.  Removed it and made a block off plate.  Going electric pump
The engine looks great. How did you manage to bolt it to the torque converter? Did you have the car off the ground?
It is going to be a blast getting use to all the new power.
Yes.  Car is up on ramps. Easy to get at the nuts for the torque converter
Good work dude.
