Topic: My GTbird build (Read 63413 times) previous topic - next topic
My GTbird build
Reply #60
There is a smaller brake Booster that will clear. I believe it's the Fox stang one, should bolt right up if I remember right.
My GTbird build
Reply #61
Well I pulled the booster off and got the firewall adjuster installed and it should work now just with limited range but I can make that up at the fork end.
I finished the brake lines and adjustable valve so now I can drop the motor in. I also started on the new front suspension and got the CC plates on.
I also got all my dash parts and gauges figured out for a layout I like. Im going to machine the .125 textured plastic sheet to overlay the stock bezels in between the vents then use some nice button head capscrews to mount the new bezel to the originals so it will kind of have a 85 Mustang GT look to it.
Brian R.
88 2.3t Ranger
My GTbird build
Reply #62
That is the method I used as well, except with aluminum. The textured plastic panels will look great!
My GTbird build
Reply #63
Finally got the front end all together as of today. 87 brakes, MM braided hoses,95 Cobra coils with 1/4 coil cut off,rebuilt A-arms,KYB struts, MM cc plates and all Energy Suspension bushings for the stock swap bar.
I also got this coil spring installation tool from Maximum Motorsports that made putting the coils in so much easier.
Wont be able to work on it again until weds but I should be dropping the motor in then.
Brian R.
88 2.3t Ranger
My GTbird build
Reply #64
Quote from: deathbypsi;456278
My 84 TC shows 5/83 vin#148035
I was told my car was formerly owned by NASCAR driver Kenny Schrader and some paperwork in the glove box seems to indicate that as true.
Seems to agree with the info I have when it was for sale many years ago.  Assuming there isn't more than one Kenneth Schrader. :hick:
Does this look like your car?
X
tbirdregistry.com
26480
27373
My GTbird build
Reply #65
Yep that's my car. I just peeled off that sticker on the windshield over the weekend!
Where you find that pic?
Brian R.
88 2.3t Ranger
My GTbird build
Reply #66
From the ebay ad back in 2007.  I guess that might be the time frame it sold and went to Fl?
X
tbirdregistry.com
26480
27373
My GTbird build
Reply #67
Worked on my cluster lastnite. Think its going to look real good.
Using Speedhut tach with shift lights and their GPS speedo that has a bunch of cool features. Autometer and AEM will round out the rest of the gauges. These were all left over gauges from some of my other builds so instead of spending good money on new ones Im going to do my part for the environment and recycle these.
Brian R.
88 2.3t Ranger
My GTbird build
Reply #68
And here is the finished layout. Im real happy how it turned out! Gave me that 85 Mustang GT look I was going for.
Brian R.
88 2.3t Ranger
My GTbird build
Reply #69
Looks great. You're doing some nice work on the ol' bird.
 S O L D
My GTbird build
Reply #70
Reached another milestone moment lastnite also.
Motor is in.
Brian R.
88 2.3t Ranger
My GTbird build
Reply #71
Looks great!
My GTbird build
Reply #72
Thanks Chuck. Hope mine turns out half as cool as yours!
Brian R.
88 2.3t Ranger
My GTbird build
Reply #73
Mine could really stand to be gone through again...
Glad to see another 83 getting some love.
My GTbird build
Reply #74
Quote from: deathbypsi;456482
Motor is in.
Which Griffin radiator is that?
