Topic: 5.0 cfi to 5.0 ho carb swap help (Read 1490 times) previous topic - next topic
I'm wanting to put a 5.0 ho roller motor into my 84 thunderbird 5.0 cfi I have a 1990 mustang by motor that I'm planning on putting a carb on all of that is simple to me but what I need to know is how do I make it run once it's in like what do I need to use for a distributor and inginiton system and how do I wire it up and have it all run
Distributor- Get one for a 85 mustang 302 GT carb with steel gear
Ignition- order ign module (duraspark) for the same mustang. Other option, run GM hei module. You can request it using 78 camaro with 350. I went with the hei module over the duraspark myself. Coolcats site has a good write up.
