Topic: Soft ( low ) peddle after 8.8 TC rear axle swap (Read 8200 times) previous topic - next topic
Ok, I have done a search and getting many answers. Here goes, I had a buddy swap in a TC rear into my 87 bird(5.0). It went pretty smooth minus a couple snags. 1st after bleeding brakes multiple times they still feel soft. He didn't swap the proportioning valve with a TC unit..Is there a difference since my PV is for drum brakes and the TC is metered for disc? Should I swap the MC next and if so what is a DIRECT swap? Last how can I get the emergency brake connected? He said its different on my car than the TC. Thanks, Ray.
 S O L D
Do you still have the factory master cyl?
Quote from: Ramos617;454448
Yes its the factory M/C.  Ive read that changing to a 84-86 Crown Vic unit or a 93 Cobra M/C would be an improvement.
 S O L D
Yes,
With the stocker it's pushing too little fluid
Stepping up to a larger bore MC will push more fluid at the trade off of less fluid force so going too large will result in a stiff pedal
I would highly recommend tossing the stock PV valves and just get an adjustable one that way your rear bias can be tuned to your complete setup as well and handle any later brake/suspension changes
Mechanic called yesterday. Axle swap is complete. There was a collapsed line causing the soft peddle. I also had '05 Mustang springs installed front and rear so kinda worried how it looks. Also he said I need a new speedometer gear , MPH are way off now with 355 gears. That's a cheap easy deal tho. Just gotta figure out which 1 to order. Thanks to everyone with tips/advice through the swap..............Next up bigger front brakes.
 S O L D
Bigger front brakes and TC brakes in the rear will require you to swap to the 93 Cobra MC.  There are several threads on here where we have discussed this as the setup on these cars is basically identical to converting over a Fox Mustang to larger brakes.  Just search "combination valve" or "cobra master cylinder" or "SN95 brakes" and it will give you a ton of reading.
http://www.foxtbirdcougarforums.com/showthread.php?36678-Need-some-advice-one-5-lug-swap-sn95-brakes-setup&highlight=combination+valve
Will changing the MC be enough or will I need to swap the booster as well? I have started collecting parts and have the Cobra MC on the list.
 S O L D
I want to see how the 05 springs ride height looks.
Most folks are good with the stock booster and a 1" bore MC with the 11" front fox brakes and the TC rears. If you are going to move up to the Cobra fronts and rears (just assuming both with a five lug conversion) then you would want to move to the 93 Cobra booster. Some have gone ahead and installed the Cobra booster antiting the full upgrade at a later date with good results.
Quote from: Aerocoupe;454665
Aerocoupe, I have collected the needed parts for upgrading the front brakes  Spindles, rotors,calipers etc. Also ordered a 93 Cobra mc and booster just to be safe. My question though is dos the adjustable PV "replace" the stock unit or is the flow still directed through it and controlled by the adjustable? Also will the 3-2 port adapter from American Muscle work( already made=less headache lol) Thanks for your input as always. Ray.
 S O L D
To see what you need to do with regards to the proportioning valve go to post #36 here:
http://www.foxtbirdcougarforums.com/showthread.php?32920-4-to-5-lug-swap/page4
As for the 3-2 kit I could not find it on American's site.  Can you post up a link to it?
Thanks for link on PV.... oh, after reading my post I believe the adapter is on Late Model Resto's., site...
 S O L D
If your '87 has the factory MC in it then you already have the metric threads on your brake lines like the 87-93 Mustangs and your stock MC has three ports in it like the 87-93 Mustangs.  The difference between the 93 Cobra and the 87-93 Mustangs and your Bird's MC is that it has two ports of which are metric threaded.  The 3-2 kit converts your plumbing to work like the 93 Cobra and 94+ Mustangs.  LMR sells the Maximum Motorsports kit which is $5 less on Maximum's site.  You need the following from Maximum if you have not already ordered the parts:
MMBAK-3 which is the 3-2 kit
MM-2450-A which is the plug you will need once you gut the proportioning part of the combination valve
BPV-1 which is the manual proportioning valve
Got my 93 Cobra booster today. Its a reman from Cardone... It looks much bigger than my old unit. Will it fit with out issues or will I need to "massage" the strut tower like some of the Mustang guys have to do to make it fit. Also got the line adapter. I now have everything to make the swap:)
 S O L D
Massaging the strut tower seems to be a car to car thing and I would blame that on the wonderful Fox Body assembly tolerances or lack of.  I have heard of guys having much better success in not dimpling the strut tower if the motor is out.
