Topic: Hey guys update on instrument cluster wiring. (Read 14672 times) previous topic - next topic
Reply #45
Stop pulling the battery cable with it running or you'll soon need a computer as well...
Get yourself a meter and incandescent test light(std bulb, no LED )... Ign switch off, test for voltage on alternator at black/orange and yellow/white wires(you can use test light)... If no power there is a blown fuse link... If there is power, then the excite circuit from orig alt light isn't functioning(of course this is what's been altered)... This can be verified by checking for voltage on the red/green wire on regulator with ign sw on & engine off(again use test light)...
When it's running use meter to read voltage at battery, anything over 12.6v indicates it's charging and it should be 13.5 to 14.4V...
Reply #46
Hey guys so thanks again  so I decided to wire the alt reg my self ran a fuse block and  s to the battery and I to ignition  guages reads in POS and we are changing.
