Topic: code 41 (Read 3119 times) previous topic - next topic
code 41
anyone ever had to struggle with clearing eec code 41?
yes it could be a dirty 02,,, shop manual indicates I may be running lean as well.
Fuel pres is fine under load and in park.. I did not test fuel pressure while driving though because I haven't modified my tester to make the hose longer.
code 41
If possible have you swapped the O2's from right to left to see if the code follows the HEGO?
Darren
code 41
Quote from: Aerocoupe;452724
Darren
Try this first. If the code follows the HEGO just get a new one (or pair).
code 41
well, the code 41 I look up in the shop manuals don't tell me "which one"..
code 41
Is the car a V8?
Darren
code 41
Quote from: jcassity;452736
41 - System Indicates Lean -passenger side(KOER), No o2 Sensor Switching Detected. always lean -passenger side(M)
code 41
I had this problem when i still had emissions testing when i still lived in the city. At a higher idle it went away, so i just raised the idle.
Few weeks ago my car started running like . I got o2's map sensor and tps. After replacing the map sensor it ran normally and o2 codes went away.
code 41
Quote from: thunderjet302;452743
your right,, it does
I missed that.
code 41
o2 sensors totally fixed the several year long intermittent bucking !!!!!!!!!!!!!!  excellent.
now problem 2,, I actually have to install them in the pipes
thanks
code 41
Quote from: jcassity;453435
thanks
How did it fix the issue if the oxygen sensors aren't in the exhaust?
code 41
bucking is gone,, something changed.  makes no sense to me other than these are clean and the others are probably dirty?
