Topic: Cause of Steering Vibration/Normal for ford cars of this era? (Read 8338 times) previous topic - next topic
Side to side movement is definitely a wheel balance/bent wheel/alignment issue. If the wheel was vibrating up and down and you could feel it in the seats then it would be a driveshaft/rear end issue.
If nothing else it sure looks good sittin' there!!!
I really don't know if I like 87 or 88 XR7's better....so much winning everywhere.
Try rotating your wheels from front to back and see if that changes anything. That would show up a bent wheel.
Quote from: Herbsbird;452633
+1. Try this first.
I'll have my mechanic try rotating the wheels around to find the culprit/s; he suggested rotating the rims the day I had the G/T's put on. I think the ride is defenately a result from both the front end and an old ujoint. Thanks for the advice.
However, none of this stuff prevents me from treating every stop sign and red light as a staging lane...
Post when you find out what fixed it, mine does the same thing.
Mike
I'll give an update after they inspect.
Quote from: whippersnapper;452651
Tree the you-know-what outta them!! :burnout:
Cause: Bent right rear Rim.
How do I intelligently go about picking up a new 10-hole mustang rim without being fooled into getting another bent rim? Should I get it checked by a garage the day of?
I got 4 10 holes off Craigslist for $50 and another 4 for $75 with good tires a few years later.
Check local ads, Craigslist, online classifieds ect. If there is slight rash its usually okay, and one of the four should be good if ya end up with 4.
Quote from: Haystack;452853
+1
Buy a set local for cheap and use the best one. Keep the rest as spares.
Sounds good, Thanks
