Topic: Test and Tune Today (Read 10478 times) previous topic - next topic
Test and Tune Today
Last shot for 2015 wasn't too bad.My son made 11 passes in 4 hours, ran a best of 16.62. Finally got some RT that might win a round or 2. New rear end is sitting on the floor, along with a shelf of parts for the 2016 season.
1988 LX, 306 with GT40P heads, Downs Upper Intake on Truck Lower, Powerdyne Supercharger and T5 swap.  Scavenger Hunt Build at it's best.
Test and Tune Today
What rear is coming out turbo coupe disc rear?
Test and Tune Today
Just a stock 7.5 open rear. 8.8 with 31 spline Moser axles, posi and 3.55 gears is going in, along with a control arm upgrade.
Test and Tune Today
Nice upgrade there
Test and Tune Today
Quote from: Matt Jewell;452343
Just did that (7.5" 3.73 Traction-Lok to a XR7 8.8" with 3.73s, 31 spline Moser axles, and 31 spline Traction-Lok with carbon fiber clutches). Very good upgrade. I'll be swapping in Maximum Motorsports control arms as well.
The rear and suspension upgrades should reduce your car's 60' time if nothing else. That will get you a quicker e.t.
Test and Tune Today
Still trying to get a feel where to go with this. Passed on a few deals on shortblocks and heads. I have always had nitrous on just about every car because it's cheap and you don't always have to use it. Wanted to stay EFI and AOD. 12 second driver would be fine. The last project was supposed to be 11's and ended up in the 9's.
Test and Tune Today
Well if I had $$$ I would do a N/A Dart based 363 with over 500hp. But that's really expensive :hick:
Test and Tune Today
Cheap Turbo 302 and Lentech AOD. Focus on drivability and mileage with power to spare.
Test and Tune Today
Quote from: Lightningbird;452694
Crank the boost till the block splits. Repeat as necessary :hick:
Test and Tune Today
I have a new Downs upper and truck lower, BBK 75MM throttle body and EGR delete plate, Valve covers, ARP bolts, gaskets, 255 intank pump.I have seriously thought about the cheap turbo kit with a cam swap, head swap and MSD BTM.But a mass air conversion, meter, injectors or going to a programmable speed density system like a classic FAST. Other than a short stint with an Accell DFI system in 1999, i always have been a carb kind of guy. I even entertained buying a complete modified Mustang and harvesting all the parts  needed and selling off the rest. With the new 3.55 posi rear, it's ok for 300 feet and then gets pretty boring.
Test and Tune Today
Quote from: Matt Jewell;452924
20 lbs of boost would cure that other 1000 ft of boring. Make it a blow through carb setup!
Test and Tune Today
No need for anything fancy, just do a twin turbo setup ala toohighpsi.com
Get a regular car and a cfi fuel injector with a throttle switch.
Test and Tune Today
Chased a couple deals on engines/shortblocks for 2 weeks, and went in a different direction. Purchased a Powerdyne supercharger kit, 42lb injectors and Pro M meter for $1000. Missed out on Edelbrock heads and rockers for $500. Still shopping for odds and ends on Mustang sites. Won't start swapping anything out until spring.
Test and Tune Today
picked up  a set of gt40p heads that were worked, motorsport E cam, H pipe and A9P ECM for $530. in 1 trip this weekend. Couple more items on the shopping list.
Test and Tune Today
Quote from: Matt Jewell;453806
Awesome score, should be making 350 easily on motor! 450 with 4-6lbs of boost!
