Topic: Things you do for your parents (85-tbird) (Read 1810 times) previous topic - next topic
XX
I changed out the heater core in my moms 1985 thunderbird.  Was not as bad as I thought it would be.  Very glad member share information on here and on CoolCats.  I started at 07:00 and finished around 14:30.
Yes it's not that bad once you get in there,  label your screws,  and just take your time
It is a pretty daunting job though
I just noticed we have the same seat covers lol,  mine are starting to look a little rough especially the drivers seat cover.
I had one trim screw left over, lol, but she had couple broken tabs, so not bad
I REALLY  need to get off my back side and swap out the h/vac unit in the blackbird too. I might do it tomorrow.............. Looking good there. Only 1 screw left huh??? lol
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Yep only one left over, I put down a blanket on the ground and put screws with panels and tried to get things separated, I think it goes to the pocket above the radio.  No rattles, so she is good.
