Topic: inside tail lights (Read 1759 times) previous topic - next topic
inside tail lights
Is there any way to open them up and clean them out? I dunno what it is, but they're ugly lol.
inside tail lights
With very little coercion, mine separated out just fine.  There was a sticky type of sealant I had to deal with but really didn't seem to be glued into place.    Maybe it was the age and it had deteriorated I don't know.  Maybe someone else has better info.
Go Fast the first time.  The tickets the same.
86 Thunderbird 5.0.  All original good weather driver. Tbird Reg #53035
86 Thunderbird TC.  All original good weather driver.  Tbird Reg # 58555
87 Thunderbird TC.  All original good weather daily driver.  Tbird Reg # 64647
inside tail lights
If you heat it or anything?
inside tail lights
Yes, you mildly heat the seam with a heat gun and *gently* separate them.  The adhesive that bonds the inner and outer together gets much softer with heat.
inside tail lights
You can throw them in an oven to soften the glue more evenly
I would recommend getting new butyl tape to put them back together, that way if they ever have to come apart again it'll be possible
I bought some for my headlights but at the time I was doing my tails I didn't have it and just used clear rtv
They look awesome and are completely sealed but I doubt they would come apart without breaking
