Topic: Looking for aftermarket wheels for 1984 thunderbird (Read 2816 times) previous topic - next topic
My 2 cents worth, get the 15x7 rims and run the same sized tires front and back. My rear tires won't fit up front, they rub on the shock. A 15x4 would need a tiny tires and you would lose front end grip very easily.
With my combo, driving in the snow can be interesting if your not careful. The rear tires try to settle in the grove made by the fronts, so everytime you correct the wheel even alittle bit one tire or the other slides into the groove. It also greatly upset the cars handling.
Even though clover leafs are fun because there is so much more grip, a slightly damp road causes the car to slide out. Once sideways, if you let go of the gas, you get snap over steer. Then when you think the car has settled and it grips again, it shoots forwards, whichever way the car is facing. The front tires do nothing.
Say you go around a corner quick and let off the gas while your sliding, the back end shoots hard the opposite direction. If your rotated around too far, it just spins out. Although it is exciting, its a pain and very unpredictable.
With stock sized tires all around, you can hit a clover leaf at speed an once you exceed front end grip, you get more of a 4 wheel drift. It is quite a bit more fun to drive at the limit when you know what the car is going to do.
Quote from: Thunder Chicken;449806
Honestly, a set of stock 10-holes would probably be the best looking wheel you could put on that car, with 235/60R15 tires.
+1
87-88 Thunderbird Turbo Coupe wheels would also look great. 225/60/16s on those.
Quote from: thunderjet302;449889
+1
Beautiful car..thank you
Quote from: Haystack;449884
Thank you for the info and I agree about the smaller rims up front.this will just be a summer only car.im leaning toward all the same size rims all around or 15x7 front and 15x8 rear.just don't know what rims to go with yet as there are a lot out there.i love the 10 holes and the turbo coupe wheels that thunder jet has.but I also still like the weld draglites and kegs fast five type.thanks to everyone helping out and your patience..
Nice looking car. Checking your local Craigslist, I see a few respectable choices available for not a lot of $$:
Decent price for these, if you don't mind the black color: http://syracuse.craigslist.org/pts/5124186930.html
These would look sharp, but the Mustang centercaps would have to go: http://syracuse.craigslist.org/pts/5097531240.html
Fortunately, they're easily replaced: http://www.americanmuscle.com/silver-ponycap-9093.html
Here's a wheel and tire package ready to bolt on: http://syracuse.craigslist.org/pts/5136264390.html
You could even add some Thunderbird center caps to replace the generic Ford logo ones: http://www.ebay.com/itm/1985-88-THUNDERBIRD-TURBO-COUPE-CENTER-CAPS-/191620898548?hash=item2c9d7edef4&vxp=mtr
Anyway, good luck.
Yes sir to always loved the ponys on these cars here mine when I had some with tbbird emblems
I even thought about getting them in 17" When I did my 5 lug conversion
And I can't argue with the stock 87/88 tc wheels, best looking factory fox tbird/cat wheel IMO
B
Quote from: cj750;450031
Anyway, good luck.
That's a good price for the pony wheels. You could get some NICE tires and still not have a lot of $ in the package. Also the 10 holes are a decent price and bolt on ready.
 S O L D
Replied to your PM, Squatch.  Hope it helps.
Quote from: V8Demon;450067
Thank you so much..rims got delivered yesterday. And I just ordered the tires.
Quote from: Squatch69;450160
Pictures?
Quote from: cj750;450783
Pictures?
They should be on within a couple weeks.im recovering from surgery on my foot and non weight bearing for 2-3 more weeks.i will post pics with them on shortly.stay tuned..I went w the vision fast five style 15x8 rear and 15x7 fronts w cooper cobra 255/60/15 rear and 235/60/15 fronts.rims were ordered from mccormick racing w lug nuts for $380 shipped and the tires from discount tire for $390 shipped.not to bad for new rims,tires and lugs.
