Topic: Fuel pump swap..... (Read 5995 times) previous topic - next topic
Fuel pump swap.....
Sorry for the thread resurrection, but where exactly did you cut the access hole in the trunk?
Fuel pump swap.....
Floor of the trunk, its under the "home plate " shaped bubble. You can clearly see the shape in Vinnie's pic, and once you pull up the carpet it will be obvious.
Fuel pump swap.....
The left side of the picture is the rear of the car. The bottom is the passenger side.
Fuel pump swap.....
Thank you gentlemen!
Fuel pump swap.....
No problem
