Topic: Throttle body studs.... (Read 1276 times) previous topic - next topic
I'm looking for a set in great shape. Anybody have any? Let me know. Thanks.
I think I just used stainless bolts
I may do that. I'd like to find some nice stainless studs (not allthread). BUT, stainless bolts may be the way to go. Thanks Jerry.
or get regular longer bolts, cut the ends, and thread them on the opposite ends
That could work. Never thought of that. Most of the bolts that long have short threads though, and a long shank.
Quote from: daminc;448514
I did that. Throttle body gaskets and stainless bolts are ~$15. Trick Flow stud and gasket kit is ~$30. I saved $15 :hick:
If you really want the studs: http://www.latemodelrestoration.com/item/TFS-51500093/1986-93-Mustang-50L-Throttle-Body-Gasket-And-Stud-Kit
What's the thread and pitch size of them?
If its standard thread, you should be able to get a 36" piece of all thread for a few bucks. If its metric, your screwed unless your really close to Canada.
Just make them:
I always just got a piece of all-thread:
-put some nuts on it (use all the nuts to hold rod in vice)
-cut the size you need with hack-saw
-use grinder to smooth down the tip (turn while you gently shape tip)
-run the nut down where you grinded it to clean out threads.
-done :)
I'm using bolts now. Not stainless. But I may just go get some stainless cap screws (allen wrench style bolts). I saw the gasket and stud kit, but already have new gaskets. I'm not an allthread fan. Yes, I'm just being picky
Either way.. I did water pump studs the same way
