Topic: Rear wheel offset (Read 2499 times) previous topic - next topic
Rear wheel offset
I'm looking to get some wheels for the 83 I just bought. What offset do I need to run to use a ten inch rim on the rear? (I have a 88 Turbo Coupe rear end swap in it).
Rear wheel offset
6.5 inch offset for 10" wheels if it has an 8.8 mustang rear end. Yours is an inch wider either side, so try a 7.5" bs.
Rear wheel offset
Quote from: Lightningbird;448602
I have an 88 Turbo Coupe rear in it. They only make the rims I have in 5.5 and 6.5. I may just go with a 15x8 with 4.5.
Rear wheel offset
What is the stock mustang 10 hole offset?
I am running 275/60r15's on some 10 holes, and they work perfectly fine. The rims are a bit narrow for the 10.8" wide tires, but the offset is perfect.
