Topic: Need tire advice on 15x8 draglite for rear. 275/60? (Read 2140 times) previous topic - next topic
Currently I have a 255/60/15.  I'm looking to buy some Nitto DR for the cougar and I'm considering a 275/60/15.  Anyone have any pics of a 275/60/15 on bird or cat?  I got a mustang rear and adjustable CHE control arms and mach springs.
I've got 315s in the back so your 275s should fit no prob
My rear setup is sn95 vert Springs, Che CA's, fender lips rolled in, and the axle  to  width is the same as stock or sn95 width
I have 275 60's on my 86 cougar. Stock everything rocking 10 holes. I had to zip tie the parking cables so they didn't rub. On full compression they rub a bit, with alot of weight in the trunk. On my 87 bird they were fine on all bit a fully loaded trunk and hitting steep rail road crossings.
If your gonna daily it, id go with a 275/50, which also would keep your speedo accurate. With the adjustable arms and a mustang axle, you should be fine.
Yea I had 275's on my slammed tc just move the cables
