Topic: bleeding the master cylinder? (Read 17708 times) previous topic - next topic
Reply #45
I installed the Cobra MC on my 87, and replaced the factory prop valve, with an adjustable prop valve.... like night and day stopping now... I will do the same on the vert, plus add the booster...it stops ok right now, but theres always room for improvement seeing it has a 5 lug swap on it too
Reply #46
Quote from: daminc;448347
I think I'm gonna try the old school hold the pedal down method this time...I already gravity bled, and suction bled them before the MC change...
I never do it any other way.
to bleed I use a machete
pump up the brake, while holding pressure..........then......
put the blade down on the pedal
tilt the steering wheel all the way down
now bend the machete till the handle is under the lowest part of the steering wheel and walk away.
loosen bleeder and the machete pushes brake pedal down and holds it there... acts like another person.
wash rinse and repeat
protect pedal with something under the blade
Reply #47
i do the same thing but have a small crowbar that will fit between the pedal and the seat
Reply #48
I just got that $30 pneumatic bleeder from harbor freight. Woot woot
1988 Mercury cougar XR7- 302 bored .030 over, gt40p heads, F303, AlexsParts spring and seal kit, explorer upper and lower intake, 70mm tb, maf conversion, 75mm maf, fenderwell cai, 24 lb injectors, T5 conversion, bbk h pipe, Slp lm, 3.73 rear, 4 wheel disc conversion, 5 lug conversion. :D :D
Reply #49
Quote from: jcassity;449036
Machete? I use a big wooden dowel. Less chance of me cutting something in the car ;)
Reply #50
lol... I was wondering who else caught the machete comment
