Topic: Spark plug wires? (Read 5169 times) previous topic - next topic
Spark plug wires?
Hey again everyone!
I've got another question.  I noticed yesterday and today that the Cougar has a rough idle, where you feel sort of a rumble.  It still has the pep it has had since I changed the plugs (still have the original plug wires on it).  I'm not sure why it's doing this.  I noticed yesterday when I put it in reverse to back it out of the car port... it acted like it wanted to hesitate.  It's still sharply responsive when you hit the gas a little, but the rumbling I feel and the hesitation it gave when I put it in reverse... does anyone have any suggestions as to what it could be?
Thanks in advance!  Everyone here is awesome!
Tommy
Spark plug wires?
Run codes and do a base idle reset.
Spark plug wires?
Quote from: Haystack;446210
If I had a code scanner, I would, but unfortunately, I don't.
Spark plug wires?
Quote from: thetommyboy2k;446219
Do you have a paper clip? If so you can pull the codes.
See here: http://sbftech.com/index.php/topic,2471.0.html
List of codes here (your car will have two digit codes): http://sbftech.com/index.php/topic,849.0.html
Spark plug wires?
If your car hasa functioning check engine light, you can just sit in your chair after inserting the paperclip.usually i record the codes with my phone to make sure i don't miss anything.if not, you'll need either a test light, a buttstuffog volt meter, or a 12v buzzer.
