Topic: Finally got something done (Read 3621 times) previous topic - next topic
Re: Finally got something done
in our cars, all the current for the lights passes through the headlight switch, and then when you turn the fogs on, thats even more strain, and it could burn up the switch, or some of the wiring under the dash if used for extended periods of time, that, and with the  relays, youll get "cleaner" power to the headlights and fogs, meaning theyll be brighter and more crisp
http://www.turbotbird.com/techinfo/installing_headlight_relays.htm
http://www.turbotbird.com/FAQpage/FAQpage.htm#Rewire_Fog_Lights
check all that out, i want to do the same thing, but id also like to be able to turn the fog lights on independantly from the headlights, so i might still modify those diagrams a bit to my liking
