Topic: New pics of the Sport today..... (Read 9902 times) previous topic - next topic
Oh no.....I'm not saying anything. I'm planning on keeping the Sport forever. I'm just saying that hood is more than special. Not just for the awesomeness of it, but it has a story behind it. It stays. So does the Sport. I put too much of ME into that car, and STILL have stuff to do. Carpet, console, engine stuff, a few special plans for the trunk area, etc.
Now if you could only figure out a way to duct air from the hood scoop to the air box.........
If I install a carb this summer, I'd install a very factory looking air cleaner for ram air cars like the old early 70's, late 60's Mustangs and Fords. After that, the scoop can be made functional easily.
Quote from: vinnietbird;444898
True. Too bad you can't make the scoop work with EFI.
It has a lot of space under there. Well, It did. Once I installed the stud mount rockers with the aluminum heads, I needed taller valve covers, then a taller plenum spacer, now....not so much room.
Carb swap is a serious consideration I'm having. About had all I care to deal with on this EFI. If I had a  ton of cash, I'd run it to a shop and have them make it right, BUT, I don't, so, we'll see what happens by the beginning of Fall this year.
The more time that goes by, the more a carb set up sounds good to me, with functional ram air from the hood scoops.
It would be a setup like the link below (except waaaaay cheaper). I can fab the base plate for the hood and the air cleaner assembly easily.....
http://www.ebay.com/itm/1971-1972-1973-FORD-MUSTANG-RAM-AIR-PARTS-FOR-HOOD-BOSS-MACH1-/281589030845?pt=Motors_Car_Truck_Parts_Accessories&hash=item4190039fbd&vxp=mtr
when you swap to carb...we need to talk pieces parts for my vert efi swap
Why go carb? Driveability suffers, fuel economy suffers and btw it's already EFI. Is there something seriously wrong with the efi?
Daminc, I have A LOT of ford EFI stuff if you need something for a swap. I need to unload this stuff before I start building something else. Vinnie I can help you figure out any probs with your efi.
Reply #39
I've got a few EFI bits as well...engine harness, fuel rail or three, A9T eec...
Vinnie...don't go carb..I think you'd have more dislike for that than what's causing issues now.
Reply #40
I have no idea what's causing the issues, probably needs a tune by a professional. That is NOT in the budget. I have some serious thinking to do. BUT, that's a matter for the tech section.
Jerry, if I go carb, I can fix you up. I will know for sure which direction I'm going before the end of summer.
Reply #41
i hope to find all my parts in the next couple months...
no problem though.... I know they're out there waiting for me
Reply #42
Jerry, I have an Explorer lower intake you can have. I also have a GT40-P upper intake. But the middle hole on the lower intake would have to be plugged. Yours if you want them.
I had thought about threading that middle hole and screwing a plug into it.
Reply #43
Vinnie,
An SCT chip and tune is about $500 tops. That is the chip, dyno time, and the tuner's time. With your mods it might take an hour total to tune the car once it is strapped to the roller and get it where it needs to be. Unless you just want to swap over to carb to utilize the hood as that would be pretty cool there are still issues with tuning a carb. I have both and I can tell you that given the opportunity to do it again the Bird would be injected.
I understand the frustration you have and are still going through but these EEC's are over 20 years old and they are very slow. If the EEC has to start compensating for things that are out of parameter it slows them down even more as they have only so much processor room to do this function before it starts affecting the EEC's ability to perform its normally programmed duties.
Darren
Reply #44
Quote from: vinnietbird;444980
I think I'm just needing fuel rails, and Tbody
