Topic: Coolant leak!!! (Read 2068 times) previous topic - next topic
Coolant leak!!!
I just discovered a few minutes ago that I have a coolant leak on my 85. I'm not sure where it's coming from. It's dripping from under the crank pulley/vibration damper. My guess would be the water pump gasket has gone bad.
Does that seem to be the most likely? I have a three day weekend and I'd like to enjoy my car for at least one of those days. I need to get it fixed soon if possible.
Thanks!
Cornfed85
1985 Thunderbird - 3.8 V6, C5  :ford:  :birdsmily:
Coolant leak!!!
Either that or the coolant hoses, or the lower intake
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
Coolant leak!!!
New pump is my guess
Coolant leak!!!
I assumed that my waterpump was leaking once, replaced it, fired the car up and it still leaked. The timing chain cover leaked.
Coolant leak!!!
Quote from: Haystack;443346
LOL!,, yeah tell me more,, no just kidding.......
so then you do your due diligence to replace the timing cover  gasket only to break off a timing cover bolt...... almost forget there is allen head bolts in the bottom of the cover ect,,, then it all just snow balls from there.
Coolant leak!!!
The covers do leak that is why i replace both after thoroughly checking out where the leak is actually coming from. If the coolant is coming from the weep hole it is not brain surgery to the fact that the pump is shot. Just saying
Coolant leak!!!
The pump is a straightforward procedure that I can do with the tools I have. I have everything torn down and the old pump removed. It's definitely the original (it still has Ford stamped on it). It's covered in sludge on the outside, but it is surprisingly clean inside.
Is there anything I can look for tomorrow to check the timing chain cover without having to pull the crank pulley?
Cornfed85
