Topic: ?? About throttle bodys (Read 4360 times) previous topic - next topic
Question if I were to replace my current T/B on a stock 5.0L 302, to say a 75mm or a 90mm would I tell a difference? Heck I dont even know what the stock T/B mm is anyways. Okay call me dumb for asking but hey gotta ask if you want to know right.....
Just keep the stock throttle body until you swap the intake. A 65mm is about as big as you will need to go until you swap heads and cam and get a little more wild. 75 and 90 is WAY too big. Swap on an Explorer intake, 65mm t-body and a 65mm egr spacer. Until then...let it go.
Quote from: dan1863;442902
You could slap a 75mm on it and not notice much of a difference. General rule of thumb is (general rule=does not apply in all situations)
65mm TB: stock and or GT40 iron heads
70mm TB: 302-306 with a mild cam and aluminum heads
75mm TB: 302 with a aggressive cam, big heads and intake or a 331+ engine
90mm TB: 331+ engine
Then again my wife's '12 3.7 Mustang comes with a 73mm TB from the factory. So take that for what it's worth.
Read:  http://sbftech.com/index.php?topic=15585.0
Quote from: V8Demon;442956
Yep. Really if you're going to buy a throttle body just get a 75mm. Or bigger. I only have a 70mm as I found an almost new 70mm Edelbrock TB at the junk yard and got it for ~$35. Otherwise if I was buying new I'd get a 75mm.
