Topic: Ground issue??? (Read 5658 times) previous topic - next topic
Ground issue???
Do you have an aftermarket radio installed?
CoogarXR : 1985 Cougar XR-7
Ground issue???
Quote from: Stealth;441327
Does the car have Automatic Climate Control? You mentioned the blower runs when it should not. Just thinking there could be some sort of problem in the solid state blower speed controller. It is below or behind the glove box, you might try unplugging it.
Good idea, but the EVTM shows the 84 still has the mechanical ATC and not EATC.
Ground issue???
There are 5 connectors behind the panel you took off to remove the EEC computer. Don't know how many you may have messed with.
Pages are 84 EVTM pages.
C43 3pin (page 43)- T/LG D Fuel pump relay coil ground (EEC pin 22) /  R  Hot with key on to fuel pump relay coil. /  Y Hot at all times to fuel pump relay.
C284 2pin (page 155)- DB/LG Hot in run from ATC function switch to thermal blower lockout switch / O  Lockout switch to blower motor.
C252 2pin (page 119)- Y  Hot at all times to rear window defrost relay /  GY/Y to rear window defroster.
C373 1pin (page 101)- P/Y With trunk release pushed, hot in Accy or Run to trunk release AND KEYLESS ENTRY MODULE pin 7.
C252 4pin (page 80 & 81)- LG/Y Hot at all times to vanity and map lights. /  BK/LB dome light.
  Pages (131 & 132)- DG/O & W/LG H to RH door speaker.
You say the blower runs with the key off. If it is running with the ATC function selector in off, the following may be possible.
C284 and C252 are both 2 pin connectors. If they got reverse connected it may be possible to have the C284 Yellow hot wire connected to C 252 Orange wire to the blower motor.
The thermal blower lockout switch is on one of the heater hoses. Any chance the orange or dark blue/light green wires there got crossed up with a hot wire?
You say the door ajar light staying on dimly, goes away when you unplug the cables to the Keyless Entry module.
The door ajar Switches (page 99) put ground on the ajar light when a door is open. They also put ground on pin 14 of the keyless entry module. When the doors are closed, keyless entry module pin 14 is providing a partial or resistive ground to the light.
The keyless entry module (page 101) also controls the door locks which you say are acting strange.
Sounds like the module is either bad or some wiring changes you made are causing it to be erratic.
 One thing I notice, the trunk release switch puts voltage on pin 7 of the module. When the release is not pushed, pin 7 should have ground through the release solenoid. Check if the trunk release works to rule this out as a possible cause of the problem.
Also the door ajar switches are on the door latch inside the door, not the door jamb dome light switches.
Ground issue???
The trunk release works.
No, I do not have an aftermarket radio... and I would love to find another "good" Ford Premium sound radio to replace mine, as the LED that lights the LCD has burnt out.
softtouch: I miss-read your post earlier, I have not attempted to unplug the keyless entry module yet. I will try it as soon as I get a chance. I will also double check the 2 wire connectors, but of the connectors in the kick panel, the only one I recall disturbing was the fuel pump wires (I had to ground the tan and light green wire for the fuel pumps to work without the computer).
My car does have the automatic temp control and it has had some issues in the past before the conversion... The blower has never worked on the "floor" setting no matter how hot or cold the coolant is. I read about the cause of that problem in the EVTM.
Ground issue???
Factory radio doesn't have LED backlight for LCD, it uses small 0,5W incandescent bulb. You can buy them very cheaply from dealextreme - http://www.dx.com/p/0-56w-indicator-yellow-light-bulbs-for-car-audio-system-5-pack-47983#.VIJAqMlARwE .
Ground issue???
Well, that a good to know... The 194 looking bulb that lights everything else does work, just not the LCD.
Ground issue???
It's quite long time since I restored my spare radio, but I think, there are those small bulbs mentioned in my last post (incl. link). Maybe a bit bigger 1.2W bulb, but definitely not 194. Open it and take a look (and send a photo).
Ground issue???
The keyless entry module seems to have cured the door ajar light and the self locking doors, as the power door locks have been deactivated with the module unplugged. The blower motor is still getting 12V when the key is off, so I guess I will keep looking for that...
Ground issue???
Quote from: tbolt64;441422
Will switching the ATC function Selector to OFF, turn the blower off?
Ground issue???
Yes it does... I was just trying to make it "right".
Is there anyway of finding a functioning keyless entry module?
I guess, that means Im asking if anyone has one for sale?
Ground issue???
Fuse 9 is the power source for the function switch. Pull fuse 5 (page 16 & 18) to see if there is a back-feed to fuse 9 from the fuse 5 circuit.
Also do you know whether the car has Trailer Tow feature?
edit: Checking further, I see that fuse 5 goes to the Keyless Entry module. Have you checked to see if you still have the blower problem with the module disconnected?
