Topic: New Bird! (Read 5101 times) previous topic - next topic
New Bird!
If your staying stock h.o. specs, keep the sd setup. If you want a more radical cam or more performance oriented mods, go mass air.
I have an 87 .fi harness from my old 302 bird ill let go cheap. You would still need the salt and peper connectors to computer. Using a harness from the same year and dash style should keep your rewiring to a minimum.
New Bird!
Do you have the full digital dash, or the semi digi base cluster?
New Bird!
full digital. Will mass air require a different or modified harness?
1988 Mercury Cougar LS
5.0HO + T5 Swap + Suspension/Brake Mods
