Topic: Mass air conversion question (Read 13638 times) previous topic - next topic
Reply #45
Pin #19 on a Mass Air computer is a check for fuel pump voltage.  Both Mass Air and Speed Density have a signal to the pump relay from pin #22.  The code will show in both KOEO and CM.
Reply #46
Quote from: V8Demon;440076
i understand what should happen, but I never added such a wire, and have no code. I hate digging down in that kickpanel so I won't be looking at the harness anytime soon.
1988 Thunderbird Sport
Reply #47
Just check the relay in the trunk first.  If its not jumped there it's more st likely spliced straight from 22....
Reply #48
Seek, are you running Mass Air or Speed Density?
