Topic: Rocker adjustment.... (Read 35650 times) previous topic - next topic
Reply #105
Quote from: thunderjet302;440207
You needs da codes! ;)
Seriously without codes it's hard to guess exactly what is going on. I would stop swapping on parts till you get a chance to read the codes.
then its 95% chance of being  a  mechanical problem.
Reply #106
Going to do a KOER test soon....
Reply #107
I'm taking the Bird to Oriellys to do a balance test. There machine is probably way more accurate than mine.
Reply #108
I ran it at Oriellys....code 60, 80, and 90. Not sure if the test was a good one. I'll do my own on my py little machine later.
Reply #109
Vinnie,
I'll look when I get home but I don't think those are even real codes.
Darren
Reply #110
I don't either. Not in my code book. I'm going to have it re tested when Lance, their manager gets back. It was hid day off. The guys at Oreillys had NO clue that the Thunderbird was even a Ford. Really? Douche bags.
Reply #111
Quote from: vinnietbird;440391
I don't have any emblems on my car right now, but I've been surprised by how many people recognize the car as a tbird. Even my tails are currently missing their emblems. All is not lost with the human species!
1988 Thunderbird Sport
Reply #112
60 means cylinder 6 failed the balance test, 80 means cylinder 8 failed, and 90 means all cylinders passed.
You can run the balance test by flooring the gas pedal at any point after codes have been ran, within two minutes. Once the balance test has finished, you can run it again up to three times. As long as you get a pass the first two times, your balance is within specs.
The tps voltage doesn't matter. My cougar reads 1.25's at idle and does not surge one bit.
*edit*
As long as tps reads between .59 and 1.29volts, and reaches 3.5's over base to reach wot.
Reply #113
If you want ill make a video of the balance test on my cougar with a test light and a paperclip, and upload it to YouTube.
Reply #114
Not yet haystack. I'm going to run a test with my little tester. It did good a couple of years ago when I did that test. It'll work fine, if the guy at Oriellys can't do it. If so, I can just watch.
Reply #115
Good luck, and let us know.
Reply #116
Will do. I hate to be left hanging when people are looking for answers. Thanks a lot.
Reply #117
Quote from: vinnietbird;440379
That would be cylinders 6&8 failed the cylinder balance test and they all passed. That's only possible if the test was run three times.
Vinnie if you have a code reader the KOER and cylinder balance test is easy to do. Just warm the car up and shut it off. Then plug the code reader in. Turn the car on and then press the test button on the code reader. After it spits out the last code do a brief wide open throttle. The computer will then run a cylinder balance test. After it has run the test you'll get a code (90 is pass, any other number is the cylinder that failed ie 70 is cylinder 7 failing). You can run the test up to 3 times in a row to narrow down a cylinder that isn't contributing fully.
Don't be afraid to run the KOER test and cylinder balance on your own. It's easy and you really can't screw up the car :).
Reply #118
As long as your tester can pull codes (or you use a paperclip), you can run the cylinder balance test and get the codes. After all, all the tests are performed by the EEC - the code reader only starts the test and counts the flashes slowly sent by the EEC. The same thing that can be done with a paperclip and check-engine light.
No obd1 tester is better or worse than another.
Good luck - hope you don't find weak cylinders! That can be a pain to diagnose. You may want to re-run the set of tests a couple times to make sure you get consistent codes. If not consistent, the issue can be anything from a rotor, to a vacuum leak. http://www.corral.net/tech/maintenance/eecivtest-balance.html
Reply #119
I've run one before. No worries. I just figured since I was out, and they had the device to check it.....let them. I'll do it again myself and see if I come up with something different.
