Topic: TC 5.0 swapped, Hello A/C!!!!! (Read 8641 times) previous topic - next topic
I will have to look at my harness when I get home tonight but you should be able to tell from the top of the relay which two wires are the coil and which to are the contacts.
87 TC
I got it!!!!!  down where the headlight harness plugs together next to the battery, the green/purple wire changes to a slightly different color of green with a really fine purple stripe. I took the newly found green/purple stripe wire upto where the green/purple comes out of the 5.0 harness and Bingo!!!  now I have control of the A/C clutch from the EATC!!!
